Make sure you power the +24v where it says "24vGnd" and +24v. They are big, heavy spade connectors. The silkscreen writing is swapped (the only mistake, but fortunately, there's reverse polarity protection so it's not harmful), so make sure the +24v goes where it says 24vGnd, and the 24v ground plugs into the spot where it says +24v.
What current sensors are you using?
