but a high voltage spark might, if you can get the correct voltage spark it will actually create a shock wave that helps split the fuel and give a more efficient burn but before attempting that i would try side-gapping sparkplugs if your plugs are not that way from factory
There are many plans for high voltage coil enhancers knocking around on the net. most of them refer to the 'water spark plug'. high voltage is piggy backed on the normal coil pulse.
