Old 01-13-2017, 08:35 AM   #11 (permalink)
Daox
Does it matter? Your engine is within specifications per Honda. No, its not in perfect shape. Are you considering rebuilding it? What is the purpose of testing the compression?
I found out the compression was on the low side on my Metro after having it a few months. It didn't use oil, and I continued on to get 50 mpg lifetime over 2 years of ownership. Did I consider rebuilding it? Yep, but I never did, and I never had any issues either...
If you're not looking to rebuild the engine, just make sure to keep oil in it and you'll be fine IMO.
The Following User Says Thank You to Daox For This Useful Post:
ThermionicScott (01-13-2017)
