Old 08-14-2008, 12:02 AM   #23 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Taco,
do the E-fan mod, I believe you will notice the difference - grill block or not
mine was 7lbs of rotating madness on the front of the engine
& my little 2.2L does not need that kind of drag
Then revisit the grill block
I did an extreme grill block test first
(will attach the pictures if you promise not to laugh)
engine temp only went up ~20 degrees F
clutch fan got warm & grabbed hold - very much audibly louder
took 20-30% more throttle (by the scan gauge) to get to high way speed and 10% more to keep it there
it was my first real ecomod - I was dumbfounded and crushed
now with the electric fan I have no such problems - runs at least as cool as clutch fan
I have run almost a full grill block - with gap seals
it is hot out now (90-100F) so I have dialed back to what is shown in pic 2 just in case
Name:	grill block test cover.jpg
ID:	1446   Click image for larger version
Name:	Grill block 8:08.jpg
Concrete
Start where you are - Use what you have - Do what you can.
