Take some aspirin before reading
You can dual-core the IC as well...
Or even 2 stage with standard IC primary (reduced size) and a temperature controlled water to air secondary like this .
Description
This is an enormous water to air intercooler.
The proportions are somewhat ridiculous, please make sure it will fit before ordering. If you have the room, there's nothing better.
The height, its smallest dimension, is nine inches. This intercooler is more than five times larger than our smallest core. Recommended for up to two thousand horsepower.
100% Lightweight aluminum, No Epoxy Used In Core
Fin pitch is 21 fins/inch - 12.5 air side and 8.5 water side.
Recommended for up to 2500 CFM / 2000 HP
Pressure Drop: Less than 0.5 PSI. This is not a typo! Liquid/Air Intercoolers have incredibly low pressure drop.
Inlet: 4" Outlet: 4"
Maximum water/air pressure: 70 PSI
Core Size: 9.5"x9"x9" (Endtanks add to length)
Water to Air intercoolers
I have been looking at theas
They appear to have the capacity to build any custom setup you may desire. Tie into the block (like the heater core)to aid in cold weather conditions by maintaining higher IAT +20°f . Warm up time reduction. (times required to rach high efficiency)by feeding warm/ hot air into the intake. And a supplemental radiator to keep IAT low enough.
Call a Cummins "Applications Engineer Technician " to get a specific temperature window recommendation for there ISX with your specific build and planned computer reprogramming.
With the volume of engines you are buying and retrofitting they may even send a tech to modify there engine to fit your needs.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
