Old 01-21-2017, 03:19 PM   #188 (permalink)
cRiPpLe_rOoStEr
So, why would you actually want a hand throttle? BTW since it has EFI it probably doesn't have a provision for a choke lever like the old carburettor-fed engines, but you might find a way to work around it. Other possibility would be to do something inspired on those adaptations used by paraplegic drivers. Have you ever seen that French-style hand throttle controlled by a pair of levers assembled behind the steering wheel? Make one with provisions for a lock to set it at a predeterminated position and there you go...
