Thread: Hello from PA
Old 01-23-2017, 02:10 PM   #7 (permalink)
cRiPpLe_rOoStEr
Most of the full-size Broncos from '80 to '96 that I've seen were fitted with the 300cu.in. inline-6 and a manual transmission, and most likely to be assembled in Venezuela. Without extensive mods to enhance its off-road capabilities and driven conservatively, 20MPG wouldn't seem unachievable.
Anyway, do you know the differential ratio currently fitted to your ride? And would you eventually be comfortable to try a higher ratio even if that could lead to a compromise of its towing capability?
