Teoman .
Thats a realy good price at $ 550 +58 shiping from mainland china to the states. Theas units run above $1000 new +install kit /controler. This one appers to be new. =better dill than my used 24vdc unit.with a toggle switch at 500+ a 3 amp dc-dc.
As to diy from first post:
Original idea was an instant hot water heater running propane and a 12V pump. Theas heaters are flow activated. So a check valve/isolation solenoid would be needed to prevent heater activation from the engine.
If you have power available at evry spot you stop an electric instant water heater and small pump. Googal has 21 choices under $200 evan a 115v at $89
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
