5 kilowatts times 12 volts is 60 Amps. Check my math. My living module has a 20 Amp service panel. ???
Why not get a 2nd hand heat pump out of a late-model Leaf and trigger it with a laser pointer from your living room window (for example).
Your math is close you forgot the fuel ...72w + .11 ga of diesel /gas / kerosene = 5kw is correct you see diesel has over 139000btu . 1w = 3.xx btu.
Leaf heater
?How many 50# groop31 batteries aer required at $125 ea??. to heat 4galons of water and a 1000# engine from 40 below 0°fto operating. And start this engine? (Keep in mind that a battery has only about 5-10% of its CCAwhen new at this temperature ... lithium battery is not able to be charged till spring so lead is the only option. . Getting the math wrong is a fatal mistake at 40below.+windchill...
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
