Old 02-03-2017, 07:19 PM   #24 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
A bit of progress, i managed to get an injector. It is from a 1.6L peugeot GTI.
I also have a big water tank.
Just need the pump ( I already have all the electronics).
Experimentation will continue.
Another idea popped in to my mind, distilling water is a bit of a problem as I live in an appartment building and it is not easy to carry water. Gas stations have water but I woudl not want to inject that in to the engine as is.
What if i put a sealed metal container on to the exhaust manifold (the container is a semi disposable item here) the water will start to boil and evaporate, travel through a hose and bubble in to my main water supply filling it up.
Obviously after a certain amount of cycles i will have to either clean the gunk (calcium buildup) inside the water can or get a fresh can.
Also i will have to have a think of a checkvalve so that the container does not suck the water back after everything has cooled off.
