Having to buy "clean "distilled watter is a major contributor to the OEM's are not using water injection. Most customers would just fill from the tap causing the system to be prone to failure and a warranty nightmare. 10% rule would render the device useless.
In the Army we had the 10% rule .
It states, You must be 10% smarter than the device you are trying to operate, in order to succeed at operating it.
Will you be injecting before or after the turbo? After the IC is my recommendation, to prevent water condensingin the IC causing a restriction or worse a sudden surge of unmetered water.
Onbord distillery. That'll do maby use a trans cooler to condense the water. So that you can have an air gap. . Insulate the pressure vessel. Be prepared for sudden presure spiks as you hit bumps and turn,stop, start causing the water to slosh onto the hot dry parts of the boiler.
Maby a small boiling chamber( like an egr cooler) with a suplly tank . To keep all of the boiler internal surfaces wet like a house boiler/Hydronic systom.
This is a very informative site
https://www.rbracing-rsr.com/waterinjection.html
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
