Old 02-08-2017, 01:14 PM   #295 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Oh dear.
Some of the info there is very very scary showing a complete lack of understanding. Like saying you could make 160 times more by vaporising the fuel. If that were true you could pull a vacuum on the fuel vapor and make it expand many many many more times in volume. It still will not change the amount of energy it contains.
You may be on to something on the combustion efficiency thoug. I am not an expert by any means, but if you can get the fuel to combust faster you can have better control over how the duration where you can extract energy from it. You will need to play with timing, injection rates and a lot of other stuff. Water injection can be used to slow the burn rate.
If you are really really serious about this, i recommend you do a bit of research in to ion sensing where the spark plugs are used to measure the pressure in the cylinder. That way you can see how fast the fuel burns (and hopefully you can see when the burning stops so you do not eject still burning gasses through the exhaust burning your exhaust valves).or find means of installing a pressure sensor on one of your cylinders.
It may be wise to befriend a good ecu tuner who is willing to work with you.
On a carbed engine unless you are running constant speed and constant load, it seems a. It difficult to tune the system. (I am more of a software guy myself so i may be biased).
