Old 02-08-2017, 05:24 PM   #300 (permalink)
racprops
My real problems is How long will it take to convert a small steady stream of gas??
Where can I get electric 12 volt heaters that can go to say 1000 degrees??
I need a air tight system that can handle 1000 degrees.
Then I need to add a little water to the hot vapor..to both cool it and to add a bit of steam to soften the combustion.
I also plan on a water jacket running around the cooling system again to cool the hot vapor back to a safer temperature but not too cool as it might re-condense into a liquid.
So how cool is right??
Rich
