Old 02-08-2017, 10:30 PM   #306 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
It sounds dirty? Recycled toilet paper is made from post-consumer waste, the paint thinner is probably is probably not used and full of paint solids.
At least, one would hope...
The waste solvent is being processed by using a paint solvent recycler.
This is what the solvent looks like after being ran through the recycler.
Its crystal clear. I have tore apart my fuel pump and an injectors to see the affects of the paint waste solvent. after using it for 5 months there were no visual or performance issues.
Its way cleaner then bio-diesel.
More info here, post 301.
http://ecomodder.com/forum/showthrea...d-28776-8.html
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
freebeard (02-09-2017), Xist (02-10-2017)
