Old 02-11-2017, 10:56 PM   #22 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Fresh ideas
Sounds like my 1500w heatgun is just under the required temperature.
Did an experiment mesured power consumption with a Kill A Watt gauge ,on a 1500 w heat gun/internal digital thermometer/ thermostat
maintain + - 5°f (2°c) 932°f (500°c)
max temp/ Max fan
warmup 1289w 11.08A
Maintain 932°f 1089w to 1289w cycletime ~ .5sec high ~ 1 sec. Low
Max temp/ Min fan
Warmup 1156w 10.98
Maintenance 771w to 1109w cycle time ~ .25 high ~ 1 - 2low
Fan only
57.8 watts .30A
add a few drops/min of diesel and you have a regen temperature without the engine running . Well under the max load for a standerd 110vac wall plug. Wether or not the CFM is within specifications to clear the ash without allowing it to become one with the ceramic. I dout it ... this could be run off a properly sized bank of suppercaps/supplemental Deep Cycle Battery to alow the regen to finish what it started.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Phantom (02-21-2017)
