I would check and clean all yer grounds especially the ones near the ECU. It is the simpliest and cheapest thing to do. They will be brown, black/white stripe wires or white/black stripe wires that are bolted to the interior wall with a 10mm head bolt.
Anytime the ECU loses the +B power or ground, the ECU will reset any stored codes and short/long term fuel maps.
Igniter #1 wires might be:
#1 blue/red stripe +B, +12 from the AM2 fuse via the ignition switch
#2 blue/light blue stripe IGT from the big connector on the ECU, pin 23
#3 blue/yellow stripe IGF from the big connector on the ECU, pin 17
#4 brown wire from ground point EE which should be through the distributor to the engine block
Looking into the igniter wiring harness connector, pin 1 is on the left.
The IGT2 wire fer coil #2 is blue/orange stripe wire and goes to the big ECU connector at pin 22.
The IGT/IGT2 wires should go straight from the connector to the ECU with no splice connectors.
![Wink](/forum/images/smilies/wink.gif)
