Old 02-15-2017, 02:39 PM   #76 (permalink)
josemapiro
Hi t vago
I'm sorry I still have not said anything, but these days I've been busy and I could not give my opinion, but here it is.
This version as you know has many changes so I will not even talk about everything, I will direct me more to the menu. To begin with I think that the menu should be accessed through the middle button and not as it is now with the two buttons.
Then maybe you should have the main menus as "Main Display, Big numbers, Statistics, Clock, Coastdown, System information, Settings" and then if necessary sub-menus.
Code:
Ex: "Settings:"
Sub menus: "LCD:" Brightness, Contrast, Color, Unit of Measure, etc.
           "Injectors:" all injector configurations, ChryslerMAP, etc.
           "Clock:" Set the time and (date) when it is implemented.
           "DragRace:" All settings for this menu
           "Coast Down Calculator:"  All settings for this menu
           "Partial Refuel:" All settings for this menu
           "Load / Save:" All settings for this menu
And other sub-menus that are deemed necessary, at the end of each sub-menu the option to go back.
What do you think of this idea?
Thanks
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (02-15-2017)
