Going back to
*Twilight Zone showed up with ScanGauge. With the ECM removed from the kick-panel and grounded with a jumper,the ScanGauge will 'connect' and allow 'Scan' function.
*if I mount the ECM back in its place,the ScanGauge will NOT connect with the ECM.
*So somethin's squirrelly with the harness connectors that I've got to look into.
It sounds like they fixed a problem that you were unaware of... but missed the actual no start problem. Due to orientation (witch way is up) horizontal all contacts good gravity is holding things in place, vertical and open circuit
Or
The remaining problems are on the truck side
Try dismounted w/remote ground agen .. confurm function with Scan Gage ,then try starting in this configuration .
Could be were the gremlin lives ?
With SG as test light wiggle each wire till SG gos lights out..
Hope the gremlin gets tired of being chased soon..
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
