Originally Posted by NHB
I don't get the idea. Why would you like to insulate the intake?
From what I've seen the intake on many cars are around 80 degrees difference between the iat and the ambient air which causes higher combustion temperatures, when I start coating the engine it will be summer so I need to avoid overheating!! And from what I understand a r-13 insulation value takes about 13 hours for the inside temperature to work its way out, so you could put a block heater in and have it maintain temp better!!
