Old 03-05-2017, 11:34 PM   #47 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
If the vehicle has a cold air intake the air intake temperature is usually with in 1 or 2 degrees of out side the vehicle. If some ones car is running intake air 80 above the out side temperature it's by design, or a warm air intake.
Higher combustion temperature gives better efficiency.
Using a infrared digital thermometer the intake on my jeep sits around 197 degrees f, and I'm sure that transfers to the in going air quite a bit! Looking into it it seems that the colder the air intake is the more thermally efficient the vehicle is. A lot of the people I see getting the best fe live in places that are regularly in the teens to below zero, but they can't maintain engine temperature so they have to use a intake heater!! After dropping the intake to as low a temperature as possible you'll need to insulate the engine to retain as much heat as possible because it takes longer to heat up, dropping efficiency!!
