Old 03-06-2017, 06:07 AM   #49 (permalink)
oil pan 4
Unfortunately gas engines don't get the best efficiency with cold air.
On paper it might look like cold air is more efficient in a gasoline engine. It is if you want to make more power cold air is better. If you want efficiency warmer air is better.
There have been a member or 2 on here that tested warn up times with a cold air intake versus warmed air intske and it cut warm up times by a 2 or 3 minutes.
