Old 03-12-2017, 07:57 PM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by ChazInMT View Post
I just replaced my 2004 Civic EX manual transmission with an LX letting my 75mph RPM drop to 3050 from 3800. I drove from FL to OH but did not see great gains in efficiency. I will be driving to Arizona then back to Tennessee in the next 6 weeks so I should have a better idea. I did remove an upper grill block that I didn't replace when I changed the gearbox out, and didn't put it back in. I also did not drive as well as I could have. It does make highway speeds much quieter not going as far up in the RPM range, a nice bonus.
Well, I'd say if you delted two things that are well-known to give you better FE (grill block and hypermiling) and still go the same FE as before the swap, then that suggests the swap might have saved you.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
ChazInMT (03-13-2017), MobilOne (03-13-2017)
