Originally Posted by gumby79
Have you been able to find a hp/tq BSFC map for your setup yet?that would tell you how low you can go on the torque converter.
No i havent found a bsfc map yet. Plenty of torque curves though. Peaks at 450 ft-lbs at 2500. And is still 350ish at idle. Assuming the idle controll valve could open up to handle the difference of a lower stall.
"20+ from a gas one ton!? INCONCEIVABLE!!!"
-Every other forum i tried to state my intents...
Total spent on mods. :$440($200 was oil. So take it or leave it)
Total returned from 10mpg baseline :$167
miles since i started ecomodding :3315 miles
