Old 03-15-2017, 08:49 PM   #106 (permalink)
oil pan 4
Building the CO2 pipe line does hurt everyone.
The CO2 was going under ground but I left out the part exactly where and really why it was going to be injected into the ground. It was going to be largely injected into oil bearing formations. The idea was to use CO2 to drive oil out of the ground instead of using water in drought stricken west Texas and eastern NM.
CO2 works much better than water for oil recovery. Then when the oil runs out the CO2 stays in the ground.
