Old 03-19-2017, 12:17 PM   #2 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by HybridGates View Post
How do I do a valve adjustment by myself?
I can't help you as far as getting under the cover, but once you are there, I wrote this awesome valve adjustment thread for the K24. DIY 4 Cylinder valve check/adjustment WITH PICS - Drive Accord Honda Forums
Make sure to check the clearance specifications for your specific engine.
Do I have to adjust the timing belt? If there is any?
No timing belt, its a chain. Party time!
How can I do a DIY alignment? It really needs it.
Can't help you there, other than to suggest to spray lots of penetrating oil on those bolts before attempting..
Winter mpg is rather bad, is this the sign of needing a new thermostat?
Possibly, you would have to plug in a OBD II reader of some sort and look at the real coolant temperature. Back when my nissan maxima's thermostat stuck open, the coolant temp would never exceed 150 degrees.
What are the most comfortable tires in terms of handling road bumps and noise? I figure if I just get those and pump up the air more I should be fine for mpg.
Also can't really help you there. Don't expect a previously comfy tire to remain comfy at 50 psi. A quiet tire however probably will remain quiet at those pressures.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
MetroMPG (03-19-2017)
