Before the advent of synthetics I owned an Isuzu I mark. That car was given to my uncle with 30K miles on it, later on he returned it to me with 156K miles on it. As part of my maintenance mentality I went to change the oil first, pulled the plug and nothing came out !!!! I dropped the pan and noticed the engine oil had turned to sludge. Mind you the car made no odd noises and ran great. So I cleaned it up and poured new oil in it. 2 weeks later the engine began making valve noises and it was never the same again.
I would never consider cutting corners on the internal functions of my engine considering the strain it is under even under mild eco-driving conditions. Spend the $30 every 9 months, your car will love you for it.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
