I am sourcing more materials.
Come to think of this, i may not be using a 100 psi bilge pump but a much cheaper windshield washer pump. I do not need the high pressure as atomization (small water droplets in this case, why they call it that i have no idea as it does not have anything to do with any fuel injector) will not play a part on the injector frontier. The vaporization will take care of that.
I had an old fridge that i discarded, but i saved some components for later on. I have the aluminium coil in the back that i intend on using for this project.
Will heat kill it off?
