Old 04-02-2017, 06:06 PM   #125 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by seifrob View Post
This sounds interesting. Would you mind to share more? Do you rely on wind pressure, or how is it done?
It does use wind pressure. It's pretty much just 2 shutter type pieces of coroplast that pivot in the middle and are counter weighted with a metal rod inserted into the coroplast, on the back side. I made a thread on it years ago and it has worked great. I had to remove it due to my car having problems with its cooling system and it got left behind in a move. I will definitely be making another.
Here is the thread, if you're interested. The nearly finished product starts around post #38
http://ecomodder.com/forum/showthrea...ock-25096.html
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following 3 Users Say Thank You to Shortie771 For This Useful Post:
aerohead (04-08-2017), BamZipPow (04-07-2017), seifrob (04-02-2017)
