Old 04-02-2017, 05:29 AM   #121 (permalink)
teoman's Avatar
A3 - '12 Audi A3
For us semi urban guys, is a grill block a viable option?
Moving in traffic can heat up the engine.
But if one really wants the grille block (and doesnt want the fan constantly coming on)
What are the options? Active grille block? Spray water on to the radiator? Is there a more effective place to spray it?
Old 04-02-2017, 10:22 AM   #122 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
This is the summer version, the winter one has no holes at all.
The Following User Says Thank You to jakobnev For This Useful Post:
aerohead (04-15-2017)
Old 04-02-2017, 02:59 PM   #123 (permalink)
Eco Sol
Shortie771's Avatar
So I thought I had already put mine in here but I guess not. Well, here is my counterweighted auto-adjusting grill block.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following 2 Users Say Thank You to Shortie771 For This Useful Post:
aerohead (04-08-2017), BamZipPow (04-07-2017)
Old 04-02-2017, 03:58 PM   #124 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Originally Posted by Shortie771 View Post
... Well, here is my counterweighted auto-adjusting grill block.
This sounds interesting. Would you mind to share more? Do you rely on wind pressure, or how is it done?
Old 04-02-2017, 05:06 PM   #125 (permalink)
Eco Sol
Shortie771's Avatar
It does use wind pressure. It's pretty much just 2 shutter type pieces of coroplast that pivot in the middle and are counter weighted with a metal rod inserted into the coroplast, on the back side. I made a thread on it years ago and it has worked great. I had to remove it due to my car having problems with its cooling system and it got left behind in a move. I will definitely be making another.
Here is the thread, if you're interested. The nearly finished product starts around post #38
http://ecomodder.com/forum/showthrea...ock-25096.html
CR-Z Current Mods:
Max Sidewall PSI
The Following 3 Users Say Thank You to Shortie771 For This Useful Post:
aerohead (04-08-2017), BamZipPow (04-07-2017), seifrob (04-02-2017)
Old 04-02-2017, 05:38 PM   #126 (permalink)
Permanent Lurker
seifrob's Avatar
I probably missed it. Thanks for the link.
Old 04-02-2017, 07:40 PM   #127 (permalink)
Eco Sol
Shortie771's Avatar
No problem. It takes a little trial and error to get the counter weight right to close it at the correct speed, but after that it works great. The only issue I found with it is that if there is a strong headwind it could potentially close early. It's not really a big deal if you adjust it for a high enough closing speed though. I tried to get mine to close around 45mph. When I do it again I think I'll shoot for 35mph, so even if there is a 15mph headwind I will still have to go at least 20mph for it to close.
CR-Z Current Mods:
Max Sidewall PSI
The Following User Says Thank You to Shortie771 For This Useful Post:
Old 04-06-2017, 02:38 PM   #128 (permalink)
divedaddy03's Avatar
Very good. Thanks for sharing! This explains things... :-)
Originally Posted by deejaaa View Post
An Idea:Open Source Hybrid/Hybrid Electric Car Project
Your mind is like a parachute, it only works when it's open.
The Following 2 Users Say Thank You to divedaddy03 For This Useful Post:
aerohead (04-08-2017), Daschicken (04-26-2017)
Old 04-09-2017, 11:12 PM   #129 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Refined the lower grill block to be much easier to remove or apply in less than a minute. The lower grill screen is now ziptied to the OEM air dam upper slat so the screen won't need to be held in place when removing/applying the grill block.
On...
Off...
I'll be building some ducting so the dual transmission coolers git the air directed through them instead of being washed off to the sides.
The main upper grill block is currently at 67% and I can easily change the configuration to 50%, 33%, or 0% just by removing the velcro zipties and the associated PVC pipe.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 04-18-2017, 11:11 AM   #130 (permalink)
a little late to this post, but I just finished installing it sunday. went from a stock chevy s10/blazer front end to a fully blocked/smoothed gmc front end. going to add a chin spoiler and some stick on foam insulation tape around the headlights and grill to seal up the gaps better. also added a small tailgate spoiler sunday.
