Long story short, coming back home from picking up my buddy from military base, my 12v battery voltage dropped from 12.1 to 8.5
What should I do so I can keep driving my Insight???
I found this on Insight Central:
"Replace the 12V battery or charge it up and disconnect the three connectors on the BCM(circled in red). This will force your DC-DC converter to stay on. Then you can drive the car without worry and we'll help you work through the problems."
Thoughts?
