Old 04-04-2017, 11:38 AM   #1 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Do stop/start systems wear out the starter motor? Discussion with an engineer.
Flickr image: Doug McCaughan
Green Car Reports has an interesting article today about engine stop/start systems. It addresses one of the most common objections many gearheads have against the fuel saving technology: that it must wear out the starter motor.
The piece is an interview with an engineer at an OEM parts supplier, who explains how the starters in stop/start cars are designed differently than conventional starters.
Major differences:
  • Lower gear ratio/higher torque starter motor reduces brush wear
  • Stouter brush material composition
  • Bearings instead of bushings
  • Solenoid separates pinion engagement from starter motor contactor functions for greater control
  • Communication with ECM to control fuel/spark in the individual cylinder which is closest to being able to fire up the engine
Deeper explanation & discussion in GCR's story:
Don't start-stop systems wear out your car's starter?
Now if only they would interview an engineer to explain why stop/start systems don't cause additional engine wear from oil drain-down.
The Following 5 Users Say Thank You to MetroMPG For This Useful Post:
Daox (04-04-2017), JRMichler (04-04-2017), Piwoslaw (04-08-2017), t vago (04-04-2017), ThermionicScott (04-11-2017)
