Welcome, yeti!
What part of Ontario are you in?
From a *modding* perspective, the stepside may give you better gains, as you can build in some proper aero-friendly taper aft of the rear fender that you wouldn't be able to do as easily on a fleetside box.
However, you'll also need to "bridge the divide" forward of that rear fender from the trailing edge of the cab, backward.
So the complete answer might be: fleetside from cab to rear wheel, modified/tapered stepside from the rear wheel to the end of the vehicle.
2001 chevy s10
2.2 4cyl
5spd
4.10 gears
high flow exhaust
true cold air intake.
If you're willing to sacrifice some power for efficiency, do some searching on warm air intakes here. Warmer, less dense air = wider throttle opening for a given power requirement = lower pumping losses = higher efficiency.
Maybe a custom variable source intake - warm for cruising, cold at other times?
Also, I'm not familiar with the range of differential gears for the s10. Can you /would you be willing to go with taller gearing to lower cruising RPM?
