Old 04-08-2017, 07:51 PM   #130 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
Donkey, it looks like your last post was Dec. 2016. How about an update? Are you still making the drive? How did your numbers fare over the winter? I followed your lead last fall and added the Kats heating pad to my oil pan and it seems to really make a difference over using the coolant tank heater alone. Diesels run better warm too. Thanks.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
TDFbound (11-20-2018), Ulmo (09-12-2019)
