Old 04-14-2017, 04:51 PM   #14 (permalink)
darcane
darcane's Avatar
Originally Posted by darcane View Post
First order of business (well, when I get my garage cleaned out enough I can work in there....) is to address some deferred maintenance items. While it's in good shape overall, there are some things that need attention. Fortunately, I bought it for 25% less than the next cheapest comparable car out there so I can afford to put some money into it.
Known issues that I need to fix:
  • Clogged tubes in the sunroof.
  • Differential bushing is trashed
  • Oil pressure sending unit is giving erroneous readout (always showing 130psi, even with the engine off)
  • Radiator leaking.
  • No spare tire/jack (actually had one for a different car that doesn't fit)
Well, it's been a tough few months with the car. Addressed most of maintenance issues:
  • Clogged tubes in the sunroof. - Still need to fix
  • Differential bushing is trashed - Fixed
  • Oil pressure sending unit is giving erroneous readout (always showing 130psi, even with the engine off) - Fixed
  • Radiator leaking. - Fixed
  • No spare tire/jack (actually had one for a different car that doesn't fit) - I have the spare, still need the jack.
The slight ticking sound I noticed when I bought the car progressively got louder and louder until it started missing. After some diagnosis I tracked it down to a bum lifter, likely the result of someone at the dealership taking it for a joyride and over-revving it. Long story short, my initial savings compared to other available cars is now gone.
Oh well, it's all good now and there were lots of things we noticed while tearing down the engine that indicated it has been generally been well taken care of and not abused (other than that lifter). For example, the original clutch at 85k miles had so little wear that I couldn't justify replacing it even though we had the engine separated from the tranny. The soft rubber engine mounts easily tear if abused, and both appeared to be in excellent shape.
In the course of all this I noticed there is a small air dam under the front bumper that is almost completely ripped off. Replacing this may give a slight mpg boost... It's a cheap, soft rubber piece that sells for over $130. I think I'll go to Lowes instead.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
