Old 04-17-2017, 09:00 AM   #187 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by NoD~ View Post
QUESTION! Anybody completely remove their antenna base and rear squirter? Looking for ideas... I bought a "stick on" in-window antenna that I plan to install, but want to do it all in one shot.
Give me a link to your stick on antenna? This is on my short list.
AFAIK you're going to want a small rubber plug and some silicon. I couldn't tell you the size but the hole in the roof for the antenna mount is quite small. The mount has rubber around the base as a weather seal, and has a hollow threaded bolt with a nut on the inside, behind the headliner.
EDIT: You should probably pull the squirter pump and hose too. I believe it runs down the passenger B pillar and along the floor to the firewall.
