04-21-2017, 01:54 AM
#2122 (permalink)
i should weld
- ... you wish your non-sporty pickup truck was paddle-shift simply because it would mean you could upshift earlier than the TCM will let you
- ... you've contemplated fitting a sporty overdrive to that same truck for the same reason
- ... you still haven't gotten around to making your dream operating system for your computer because not only does the difficulty of said weigh on your mind but so does that of fitting an overdrive to a pickup
