Old 04-24-2017, 09:50 AM   #7 (permalink)
svt98t
Neutral is my favorite
The Black Pearl - '03 Mercury Marauder 300A
Team Panther
Land Yacht - '08 Lincoln Navigator L Ultimate
90 day: 15.89 mpg (US)
Tank of Justice III - '97 Ford Crown Victoria HPP
Team Panther
90 day: 24.84 mpg (US)
Lots to catch up on.
Bags were installed and KYB Gas-A-Just shocks installed in the rear. I also installed a Trac-Loc limited slip differential. I had to put my Marauder wheels on it for the Green Grand Prix.
I wanted a little extra grip for the auto cross event. (Which was a blast, by the way).
Raced the GGP and recorded 24.3 mpg, good for 1st in V8 Class, Modded. Pretty sweet, considering that I had the car on the road for 4 days.
On the following day, I had to drop off the transmission for my other car in PA. I didn't hypermile too much initially. About a third of the trip down, I filled up, and that's where the hypermiling started. I ended up with 406 miles, 17.81 gallons of gas used, for 25.3 mpg. Not too bad.
Then I realized that the tires were significantly taller than the stock tires. I used Google maps and retraced my exact route an realized that I actually traveled 456.7 miles. I adjusted my fuel log accordingly.
But the stock tires are going back on shortly.
Also:
I put the Tank though NY inspection.
You know, sometimes, it's just easier giving them the $21 and letting them do all the troubleshooting for you.
Overall: Fail
Safety: Fail
Emissions: Fail
1. Parking Brake failed
2. LF out tie rod shot
3. 1 bulb in the 3rd brake light is out
4. Check engine light bulb burnt out, resulting in:
-P0174: System too lean, Bank1
-P0303: #3 cylinder misfire
-P0420: Bank 1 catalyst system efficiency below threshold
New inner and outer tie rods, along with sleeves, and new parking brake shoes: $43. Rockauto.
The inspector was very adamant about it being a bad cat. I have to disagree. You're saying that I just drove the car 1400 miles in 6 days, and posted a 25.3 mpg, (EPA est 18) and that there's an issue with it? I'm not so sure.
I have to buy some parts and do a little work before it can be back on the road again.
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
