Originally Posted by HaroldinCR
Can Paul's circuit board be used with less parts ? I believe the Honda controller I am wanting to convert does not use Can. It runs only with PWM and another something I can't remember. I will dig up that CRS stuff and add it here ASAP
Not sure what 'less parts' means. The parts it has drives 3 phases of IGBTs and measures current, uses encoder signal.
Perhaps it could run in Volts per Hz with no current sense or encoder, but less efficient and totally different (and much simpler) code. Is that what you mean?
Is there some parts that you think are optional?
