Old 04-28-2017, 04:47 AM   #3 (permalink)
kach22i
I agree some examples, sketches, and photos of what you wish to fabricate would be helpful.
A heat gun, clamps, and a rig may get you angled bends (including 90 degrees, acute angles and gentle curves). You can them lap these bends and try though-bolts or perhaps experiment with rivets (standard and or aviation style).
There is an amazing selection of plastic automotive panel fasteners out there which could be easier to use than rivets.
I have used a soldering iron to poke holes in coroplast (and heavy fabrics) before, beats trying to drill small holes.
I once use a combination of automotive fasteners and aluminum washers to secure segments of a hovercraft skirt. Such a combination beats messing with tiny nuts and bolts with dabs locktight. Just depends on how secure you need it to be and if there is redundancy or a back up system such as tape or glue.
http://ecomodder.com/forum/showthrea...ing-14528.html
The model was glued with plastic model glue and maybe some "SealAll", and is now coming apart years later - was always delicate.
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (04-29-2017), BamZipPow (04-28-2017), teoman (04-28-2017)
