Originally Posted by gumby79
1+ on the pre heater . Eberspaecher only burns .11 usg per hr with a normal run time of 15min (from an install teck).
This image of a car in HARD cornering (Driving without brakes ecomodder style) shows that there is room for more air dam not much.
Alinment....
"Neutral" alinment. They normaly set the alinment for least driver input, =increased scuffing/resistance
Minimize use of "Defrost "settings ( plural) the system uses the AC compressor to dehumidifing the warm moist air before blowing it on a cold windscreen.
Belly pan /side skirts/ lowering
This new of a European car I assume the pan is mostly complete. Fill and smooth the under side.
Excellent.
I have the full undertrays. Its not cold enough at the moment to need the defrost system at the moment.
I may think about lowering it, I just put 2 new rear springs on it though so...
Will definitely use the webasto, even on warmer days, to pre heat.
