The colder the air intake in a Diesel, the better. If you could set an adjustable air box, similar to what is used in some carburettor-fed small aircraft, that would be better than a WAI since it would allow you to select a warmer intake for cold start and restarts on stop-and-go traffic and pick colder air while cruising.
