Originally Posted by sendler
That graph is still showing engine torque up the vertical axis since it goes to 145 even though it is labeled as load. We have no way of knowing what the corresponding throttle angle is.
I don't know that we can trust a visual so poorly labeled. It clearly says load. If it is correctly labelled, then we don't know how to read it yet. Load percent and throttle angle are different, too. I see chaos in these images.
