Old 05-02-2017, 10:27 AM   #34 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I did not relize that the curve accross the color-coded fuel consumption zones was also data (a torque curve). Great write-up. The graph would be even clearer if there were a couple load curves overlaid on it and the BMEP numbers were labelled simply torque. And this means that in the previous graph you described, for your engine, in post #8 above, that the thick and angukar black line crossing the fuel consumption zones near the top is also your torque "curve," correct? Makes much better sense to me. I hope the OP fully gets it too for his "noob" question about P&G. Thanks!
