Originally Posted by pete c
Mostly by forcing it to the highest possible gear ratio during DFCO,
Might be counter-intuitive, but dropping gears might work better to prolong DFCO, since its only active above a certain RPM. IE. if you leave it in the highest gear, it'll drop out of fuel cut at a higher road speed than a lower gear. (Or you could shift to a lower gear when you near the lower threshold of the next higher gear.) You can figure this out by watching the instant fuel consumption gauge and experimenting.
