Old 08-17-2008, 02:58 PM   #15 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Matt Herring View Post
She works a 12 hour swing shift and often has to travel to work at 4-5am when most local roads are not plowed yet or are covered with ice.
Does she switch-out to snow tires in the Winter? In any vehicle choice, snow treads make an amazing difference. I had them on an Evo one Winter and the grip was great. The same would apply to a 2wd, but perhaps ground clearance is a concern with thick snow?
With the description of driving, I would lean towards the Subarus. The low center-of-gravity of the H-4 engine and full-time AWD has made it a favorite of many in the same situation. Depending on the "feeling" of height, I would add the Outback wagon to the list.
Otherwise, the options detailed by others so far, are good alternatives.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
