Old 05-10-2017, 01:32 PM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Your speedo will be out by that much. And you'll be revving that much higher, therefore wasting that much more gas. If you went the other way, you might have some FE gains.
Your cheapest bet is to pump the tires up a good % over recommended, within the max pressure printed on the sidewall of your tires. But you'll probably gain the most by switching to a Low Rolling Resistance tire, if they make them for trucks in your size.
The Following User Says Thank You to Stubby79 For This Useful Post:
canadian_yeti (05-11-2017)
