OP, check to see if your Jeep can be flat towed. If so, the auto trans will be fine doing EOC. If not, you do run the risk of messing it up.
FWIW, I did EOC in my non-flat towable Ford Escort and never had a problem. Granted, I did it sparingly and used neutral coasting and engine off at stops to increase my mpgs.
