Old 05-21-2017, 11:30 AM   #10 (permalink)
snakedog
What joints need to be resoldered?
Does anyone have an image or video they could share?
I have a 1995 Civic EG Hatch.
The gauges do not work, initially the speedometer did not work.
I replaced it with a used speedometer from another cluster, but then the fuel and temp gauges stopped working, they are stuck maxed out.
I read on a honda forum that this may mean that the needles were moved manually, supposedly this causes ruins the calibration.
Do you if this is true?
Do you know how to fix this?
If not is there a replacement full cluster I could buy?
