If the choice is limited to just the Cruze and Camaro ignore this, otherwise and while not knowing your range I'd suggest a 4th gen Prius or Chevy Bolt if you can afford them, or a used Volt, 3rd gen Prius or any small engined Honda if TCO comes into play.
