Thread: Civic vx tires
Old 06-12-2017, 07:14 PM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wow. Tirerack.com no longer seems to carry Michelin Defenders in 13" size, but they have several 175/70-r13 tire choices still. So if you are not after LRR... get one of those. I have the VX wheels and have had Michelin Defender LRRs on them for several years. I love 'em. Excellent longevity. If I had to upgrade I would skip over 14" and go to 15"... you'll get more selection. Here is my list of swaps and weights gathered from all over le internets:
Possible wheel swaps for gearing and/or weight advantages:
13" CRX HF OEM (just under 13lbs)
13" Civic VX 8 spoke (9.7 lbs.)
14" Civic HX 8 spoke (approx 11.75 lbs)
14" first generation Honda Insight (11lbs)
14" Civic Hybrid 2003-2005 (approx 14 lbs)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)
15" Kosei K4R (10.7 lb)
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm
15" Acura Integra GSR (94-95, 16lbs)
Other size specs to double-check for any possible swap: Offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum (larger needs spacer rings).
Hope that helps.
james
BabyDiesel (06-15-2017)
